DHCP problems
Jan 11, 2008 3 Replies
Jump to replies (3)
Hi I have a DSL router with DHCP enabled, the gateway is 192.168.2.1 the wired part is working fine. But I have two laptop connecting wireless, both have identical settings, one gets its IP with no problem, the other gets a gateway
192.168.123.254 and an IP 192.168.123.150. the signal is excellent in both cases. Did ipconfig /release and renew on the faulty one, put in the gateway
192.168.2.1 but I still get an IP 192.168.123.150. I'm using WPA-PSK with TKIP
Of course if I give it a static IP all is fine, but this user travels a lot in different hotels. Could someone please help me
Thank you Thynker
On Fri, 11 Jan 2008 13:56:53 -0500, Thynker wrote in :
Sounds like it may be connecting to a different wireless network (e.g., a neighbor). Make sure you have a *unique* SSID set in your wireless router; e.g., something like your street address, not just "linksys".
Check the computer settings for the list of available automatic networks (which might trigger connection to a different network), as well as non-Windows connection manager software (which can override settings).
You could turn off "your" router, and see if the system magically connects anyway ;-)
Do you have a monitoring tool that will expose that you have actually connected to a WPA connection, and not your neighbor's open connection?
192.168.123.x sounds like a non-default setup in someone else's router. Mine will expose the connection type, a little padlock, and even show the MAC address of the WAP.
If you don't have such a tool, you could start-run-cmd and run arp -a, which should expose the ip address and MAC of the router.
My new laptop with built in WiFi can connect to access points that the old laptop with a PCMCIA card didn't even "find".
I agree about the non-default SSID. Presumably, you will configure to auto-connect at home. You probably shouldn't auto-connect to random access points that are at the default "linksys" out in the wild world.
On Sat, 12 Jan 2008 18:31:50 +0000 (UTC), snipped-for-privacy@70.usenet.us.com wrote in :
True, but you should use a unique SSID in any event.
Windows will tell you if the connection is secure or not -- View Available Networks.
No surprise there -- the big antennas in better laptops are much better than the tiny antennas in PC Cards.
