VonageOutlook is quick, easy and intuitive: Simply right-click on the contact you want to dial and select "Dial with Vonage". The dialer screen will pop up, listing up to ten phone numbers associated with that contact. Click the number you want, and your Vonage phone will ring instantly! Pick it up, and you'll hear the other end ringing - the number you just clicked. It's that simple!
VonageOutlook is an easy-to-use application that allows you to dial automatically from your Vonage (US) VOIP telephone from within Outlook. Without having to read the tiny numbers, without even dialing the phone, you can call anyone within your Outlook contact list in under two seconds with a single mouse click!
