Vonage Dialing Problem
May 09, 2005 0 Replies
I have an intermittent problem with dialing out on my Vonage line. I get a message that says that the number I've dialed is invalid. I can see the number I've dialed on the phone's LCD screen and it is correct. Sometimes I need to re-dial a few times before it will go through. This even happens with pre-stored numbers in my phone as well.
Our area requires 10-digit dialing for local calls. Is this possibly causing a problem? Or, is the phone not dialing the digits correctly?
Thanks.
Sam
