VOIP phone system for 3 international offices required
Aug 06, 2004 4 Replies
Jump to replies (4)
VOIP phone system for 3 international offices required open original image
I am in the process of setting up three new offices located in Geneva, Athens and Dubai. The Geneva office will be the primary location. In addition we will have appromimately 4 home locations served by broadband lines probably ADSL.
In order to provide inter office voice communications I wish to install VOIP telephones and connections but they should also support PSTN lines alterntive routing for local country calls.
There will intitially be 5 to 6 people in geneva and 2-3 in each other office as it comes online. Future growth would probably not exceed 15
- 20 people total across all locations.
Ideally we'll utilise broadband ADSL in each location although a leased line my be available for internet connection in Geneva. Are fixed Ip addresses a mandatory requirement for the offices AND the home users?
As this is a new company we have no legacy systems and are open to make the maximum use of our technology investment.
I am very familiar with existing PABX technology but am new to the VOIP concept. My back ground is networking \ computing in the financial markets.
Quick overview of whats out there seems to point to Avaya IP office but I've also come across some bad reports, can anyone recommend a solution they are actually using and are very happy with. Support and maintenance in all locations is obviously a key issue.
cheers
rob
The last I heard, Internet was regulated in UAE/Dubai and the government was blocking all VoIP (RTP/SDP) ports coming from the outside. Has that changed recently?
Check out the open source (GPL'ed) Asterisk PBX at
It'll give you what you're asking for, and much much more!
-- Ankur
[HINT] I guess they wouldn't know what kind of traffic you had if you shoved it through a VPN.
I'm using it (Avaya IPO) for exactly what you suggest (see locations below), and it works *very* well. They also have a range of smaller IPO's than can be used at the branch offices - use an IPO403 at the base and the
401 or small office edition at your smaller branches. Join them all up with a VPN network - take a look at the Draytek Vigor 2600 routers for this - and you have a very cheap and extremely reliable solution.
I'm using them in the USA, UK, Hungary and UAE (India next) - they're very flexible.
Email me if you want more detailed info.
Oh hell, youre right it is *illegal*. Ive just shut down the operation after readng this -
Not worth the risk. Thought we were just breaking a TOS not a federal law.
Hi, There You can try to NICSTEL 1018G/1018 IP phone( it's IP+ PSTN phone and has PSTN routing ability for remote users) or 7022 ATA( it has 1 FXS+1FXO port). Please check followings link:
