Load Balancing 3 ADSL lines
Jan 09, 2007 7 Replies
Jump to replies (7)
Load Balancing  3 ADSL lines open original image
HI, Season Greetings to all; I am new to this group I have 3 ADSL lines from the service provider i need to do loadbalancing on this 3 lines. How do i do that? I have 1 Cisco 2600 Router is it possible with that?
Experts kinly help me out.
Regards,
Karthik
In the case of using ADSL: the 2600 series has two built-in WIC slots so the OP need a additional NM-2W*) module to carry another DSL WIC card.
*) be aware of the fact that the WIC-1xDSL cards only work in certain NM's. I'am stumpled upon that behaviour some time ago :/. See:
Which one?
Not exactly an expert.
If it ADSL2/2+ rather than plain ADSL then be aware that the new HWIC ADSL2/2+ cards are not compatible with the 2600.
If it is plain ADSL: you'll need 3 WIC-1ADSL cards, Do you have
3 open slots on your router?
Hi, Thanks for your immediate responce. I am not very good in networking. The clear scenario is:
Locations B & C are connected to location A by Wireless point to point Location B have 2 ADSL lines terminated Location C have 1 ADSL line teminated
at persent i am distributing by diffrent gateways for diffrent locations.
is it possible to load balance these 3 adsl lines?
Regards, Karthik
So, where do you want to load-balance?
- At location A? where presumably you'd balance 2 ethernet connections?
- Do you want to terminate all ADSL lines at one point, stick'em in a router and go from there?
Hi, I want to loadbalance all this 3 lines in location A, loadbalance and make it as a single gatewasy to all the users, one of my friend says it's possible by the router with diffrent network segments is that true?
Let me knw
Karthik
Drake wrote:
DEAR KARTHIK, IF YOU CAN LOAD BALANCE AS MANY LINES AS YOU HAVE BY TWO METHODS
  1. IF YOU HAVE THE BROADBAND CONNECTIVITY FROM ONE SERVICE PROVIDER YOU CAN DO IT BY ETHERCHANNELING (PROTOCOL WILL BE PAgP) FOR THAT YOU SHOULD HAVE A STATIC IP ADDRESS FOR ALL THE ADSL LINKS WHICH YOU HAVE (BASIC REQUIREMENT)
  1. IF YOU HAVE THE BROADBAND CONNECTIVITY FROM DIFFERENT SERVICE PROVIDERS YOU CAN DO IT BY CONFIGURING ALL IP ADDRESS IN CATALYST SWITCHES AND DO THE INTERDOMAIN ROUTING AND APPLYING STATIC OR DEFAULT ROUTING IN THE ROUTER
  2. YOU HAVE A THIRD PARTY OPTION WHERE YOU CAN DO IT WITH THIS EQUIPMENT
THE BASIC THING IN THIS IS YOU CAN DO IT WITH TWO DSL CONNECTIONS IF YOU WANT TO ADD MORE YOU CAN GET ONE MORE THING OF THE SAME PRODUCT AND YOU CAN CONFIGURE IN BRIDGE MODE AND CALL BACK.
REGARDS DILIP.......................!
Dilip & Others,
Thaks for your valuable solutions.
Regards, Karthik
