VOIP Dial Peer has no effect
Jun 26, 2007 0 Replies
I have a Cisco 1760V IOS 12.4 router with the voice configuration below. Voice ports 2/0 and 2/1 are FXO ports connected to the PSTN.
Currently I have no problems dialing from a VOIP Phone 9- to get an outside line on port 2/0 and 9- to get an outside line on 2/1.
I have a VOIP PBX (Windows based) sitting next to this router and I assigned this router the extension number 5000. What I want to be able to do is when I dial 1-, the router will dial the extension on the PBX. On the PBX's configuration interface I do see that the router has registered itself as extension 5000, however when I dial for example 1197, where 197 is the extension on the PBX, I get a NOT FOUND. What am I missing here?
Any help appreciated!
VOICE CONFIGURATION ============================ voice-port 2/0 ring number 10 cptone CA caller-id enable ! voice-port 2/1 ring number 10 cptone CA caller-id enable ! ! dial-peer voice 1 pots destination-pattern 9.T port 2/0 ! dial-peer voice 2 pots destination-pattern 8.T port 2/1 ! dial-peer voice 20 voip service session destination-pattern 1.T session protocol sipv2 session target ipv4:10.33.39.252 dtmf-relay sip-notify codec g711alaw clid network-number 5000 ! sip-ua authentication username 5000 password 13151601181B0B382F nat symmetric check-media-src retry register 10 registrar ipv4:10.33.39.252 expires 3600 sip-server ipv4:10.33.39.252 ! ! telephony-service max-dn 4 max-conferences 4 gain -6 ! ! ephone-dn 1 number 5000 !
DEBUG (debug voip ccapi inout) ==================================
*Dec 8 17:44:07.221: //278/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind: Call Entry Is Not Found
*Dec 8 17:44:07.221: //-1/8985F2EA8349/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username=206 ----- ccCallInfo IE subfields ----- cisco-ani=206 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=1197 cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=0 cisco-rdnsi=0 cisco-redirectreason=-1
*Dec 8 17:44:07.225: //-1/8985F2EA8349/CCAPI/cc_api_call_setup_ind_common: Interface=0x840DFF88, Call Info( Calling Number=206(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presenta tion=Allowed), Called Number=1197(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T RUE, Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS E), Call Id=278
*Dec 8 17:44:07.225: //278/8985F2EA8349/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=206(TON=Unknown, NPI=Unknown, Screening=Not Screened , Presentation=Allowed), Called Number=1197(TON=Unknown, NPI=Unknown))
*Dec 8 17:44:07.233: //278/8985F2EA8349/CCAPI/cc_process_call_setup_ind: Event=0x84343B20
*Dec 8 17:44:07.241: //278/8985F2EA8349/CCAPI/ccCallSetContext: Context=0x8368F5AC
*Dec 8 17:44:07.241: //278/8985F2EA8349/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 278 with tag 0 to app "_ManagedAppProcess_Default"
*Dec 8 17:44:07.245: //278/8985F2EA8349/CCAPI/ccCallProceeding: Progress Indication=NULL(0)
*Dec 8 17:44:07.253: //278/8985F2EA8349/CCAPI/ccCallDisconnect: Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca use=0)
*Dec 8 17:44:07.253: //278/8985F2EA8349/CCAPI/ccCallDisconnect: Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
*Dec 8 17:44:07.269: //278/8985F2EA8349/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x840DFF88, Tag=0x0, Call Id=278, Call Entry(Disconnect Cause=3, Voice Class Cause Code=0, Retry Count=0)
*Dec 8 17:44:07.269: //278/8985F2EA8349/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent
