Is it suppose to be outside line? How to configure FXO? I try config FXS side with extension 20, 21. It seems to be working I can call between phones that connect to FXS ports. However, I still having a hard time setting up FXO port.
Newbie,
You may wish to investigate Cisco's Configuring the Voice Interface: 's Voice Support Resources: Cisco Voice Information: Brad Reese Cisco Repair Service Experts 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International…
Read the full replyIs it suppose to be outside line? How to configure FXO? I try config FXS side with extension 20, 21. It seems to be working I can call between phones that connect to FXS ports. However, I still having a hard time setting up FXO port.
Newbie,
Brad Reese BradReese.Com Cisco Repair Service Experts
1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272 Website:What we try to accomplish is this
here is the sample of admin site's config
! voice-port 0/0/0 signal ground start cptone US ! dial-peer voice 1 pots destination pattern .. port 0/0/0 ! dial-peer voice 5 voip destination pattern .. session target ipv4:10.0.10.2 ip qos dscp cs5 media !
here is the sample remote site's config
! voice-port 0/0/0 cptone US dial-peer voice 1 pots destination pattern 20 port 0/0/0 ! ! dial-peer voice 8 voip destination pattern .. session target ipv4:10.0.10.1 ip qos dscp cs5 media ! are we right that using this command? -> ip qos dscp cs5 media
FXS = Station side (sends voltage and cptones) FXO = Office side (recieves voltage and cptones)
The FXO port typically will accept an outside line or an analog station from a PBX. You do not need an FXO port for a good working configuration, what are you trying to do?
An example of FXO/FXS use would be:
At HQ run two analog stations into FXO ports Map station 1 (21)to site one and plug it's FXS port into Line1 on their PBX Map station 2 (22)to site two and plug it's FXS port into Line1 on their PBX
from hq, dial x21 and it rings at site 1 from site 1, pick up line 1 and dial x22 to reach site 2 from site 2, pick up line 1 and dial 0 for the receptionist
Wil my 3¢
newbie wrote:
