Skype cum FWD hardware
May 26, 2005 2 Replies
Skype cum FWD hardware open original image
I am looking for a piece of hardware that I can purchase that can be used on Skype as well as FWD? Are there any such out there?
Sidkney
If you mean by hardware headsets (analog, bluetooth, USB, with dial keypad) then they usually work with all softphones no matter if they are SIP-based like FWD or whether it's the Skype client.
Otherwise the only Skype compliant piece of hardware I ever heared of is this
"Christian Barmala" wrote > Otherwise the only Skype compliant piece of hardware I ever heared of is
IS this compatible with SIP? available in the uk?
Sidkney
