How to make skype wireless ?
Feb 11, 2005 9 Replies
I signed up for skype but did not realize that the calls are via PC. So whenever I make a call I am stuck to the PC.My headset connects to the PC.
I am used to a wireless phone and doing other things while I talk.
is there any way to make my Skype connection wireless ?
I am NOT technical.
Thanks Tina
snipped-for-privacy@yahoo.com skrev:
This looks like a good solution:
(haven't tried it myself - found it in the customer's forum of Telio, a Norwegian IP telephone provider.)
Svein
I know people who have managed to get a bluetooth headset working with Skype, also a PDA can be used if you have one.
Ivor
"Svein Høvik" wrote > This looks like a good solution:
Is their a handset available that is also SIP compatible? so it can be used on FWD?
Sidkney
SidKnee skrev:
No, it's not SIP compatible as such. But if you have an IP phone adapter, for example the Grandstream 486, you can connect any analog wireless phone, INCLUDING the Dualphone.
Svein
Svein
SidKnee:
There are wifi SIP phones available, will work without a computer, anywhere there is a wifi signal available. Zyxel 2000W, Senao, some others, but they are not cheap at the moment. Cisco does one too, just remember to sit down and take deep breath before you ask the price... Regards, Martin
Have a look at
VTA1000-Skype is SIP and Skype compatible (Yup, in one device) Connect your own cordless to it. Price is way below the dualphone.
Regards, Erwin.
Why are everyone complicating things? Why don't you use a SPA 1001 or a SPA 3000 and connect as many phones you want to the VOIP device? SPA
1001 is under $50.
Unfortunately, the solution you recommend is not available for those of us in the U.S..
Dan
