looking for newsgroup(s) with info on IAX hardphones
Jan 25, 2007 4 Replies
Jump to replies (4)
Hi...
Wwhich are (is) the best newsgroup(s) to get info about telephones that do IAX?
(Sorry I can't get a "list of all newsgroups" on my server and therefore need to enter newsgroup subscriptions by hand.)
Many thanks!
Al
This is the only newsgroup I know of. You might check out the forums at voxilla.com. They are usually active.
There's also uk.telecom.voip which the OP has also posted in.
Thanks. I often miss the UK groups. Thanks for pointing it out.
Thanks for the info!
I picked these two newsgroup names off some VoIP related web sites, and although I am not in the UK but in Okinawa, I think i'll make use of both groups - like, 2000 ideas to pick from are better than 1000 ;-)
Al
