Looking for analogue VoIP adapter with 4x FXS ports
Apr 11, 2005 9 Replies
Jump to replies (9)
Looking for analogue VoIP adapter with 4x FXS ports open original image
Can anyone recommend an analogue VoIP adapter, like the Sipura 2100, but that will accommodate 4 analogue handset (FXS) connections and 1 of more ethernet LAN connections. All to a single WAN connection to my ADSL feed.
Tim
Mediatrix 1104 Sergio Meinardi - Imperia AIP # 2271
Thanks, that would do the job but its very expensive. Do you know of any cheaper models available now or soon-to-be?
Sorry. no.
Why not just get a cheap router from Best Buy (which can be had for around $20 or less depending on them model and available rebates) and two Linksys PAP2 adapters? The PAP2 go for about $60 each. An alternative to the PAP2 would be the Sipura SPA2000. The whole set-up will give you four FXS connections and at least two LAN connections for under $150.
******* I found out DrayTek VoIP/ADSL Routers-Vigor2500V and Vigor2100V are most interesting for us. I think you can find DrayTek VoIP routers from
and
sites.
you can use two of these clts
Marco
Stop spamming already. Nobody wants your crap.
Check out
- All service VoIP provider
Henry
Actually, I suggest that everyone in the newsgroup start complaining to ebay about this guy. Even with ebay's crap customer service, if enough people harass them, they will probably do something about it. It is againt's ebay's policy after all to spam newsgroups advertising your auction. Sure, a lot of people do it once in a while and usually state clearly FA: in the subject. This guy, however, is absurd, he responds to completely non-related posts with this crap.
His ebay id is:
lvmarco
Their policy prohibiting this is stated here:
As usual, you have to use ebay's crap correspondence system to report it:
