how to combine 2 internet connection together so internet can share better
Feb 11, 2008 3 Replies
Jeff Liebermann
Yes, with some limitations. What you're looking for is a "load balancing router". For example: Methinks the Edimax BR-6641 (2nd URL above) is the more appropriate device. It will take up to 4 WAN connections and conglomerate them into a single LAN connection. They can be a mix…
I have a wireless network and when alot of people is connected to the network the pages open slow..i was wondering if i could connect 2 internet lines together to take the load off each other.im not talking to increase the connection speed but to help each other out..
Help would be great..
I was wondering if anyone knows any surefire way of bodging togetherwifi aerial...
J
Jeff Liebermann
Shotta_tav hath wroth:
Methinks the Edimax BR-6641 (2nd URL above) is the more appropriate device. It will take up to 4 WAN connections and conglomerate them into a single LAN connection. They can be a mix of cable, satellite, DSL, ISDN, whatever, or all the same type. The traffic load will be roughly equally distributed among these 4 WAN connections.
That's the good part. Now, the limitations. It will NOT combine 4 different IP's into a single stream. Therefore, if you have 4 different DSL lines at 1.5Mbits/sec each, you will NOT get 6Mbits/sec download speed from a single download. You'll get 1.5Mbits/sec and no more. The same applies to uploads to a single IP address. However, you can do 4 independent downloads, from 4 different servers, and get an aggregate speed of 4 times the 1.5Mbits/sec speed of a single connection.
Where such routers work best is situations where you have multiple users doing different things and needed more aggregate bandwidth. That sounds like your situation.
However, it's possible that you don't need a load balancing router. Have you looked into QoS (quality of service)? It might be that one of your multiple users is doing something that is screwing up the performance for the others. For example, if your broadband connection is asymmetrical (most are), a user hogging all your outgoing bandwidth (as in peer-to-peer file sharing) will saturate your outgoing bandwidth. With the ACK's on downloads being lost by this outgoing saturation, incoming download performance is severely compromised. Look into QoS or "Bandwidth Management".
J
Jeff Liebermann
Jeff Liebermann hath wroth:
There are also a bunch of more elaborate load balancing routers at the bottom of the page at:
A
Adair Winter
Another solution is to use a much cheaper WRT54GL and load DD-WRT
on it following these instructions.
are also many more expensise solutions.
Adair
Report Content
ASAP.
