Configure ATA 186 for use with ALTIGEN system
Apr 11, 2005 3 Replies
Jump to replies (3)
I have an ALTIGEN 5.0 phone system with IP extensions only. So I want to use the ATA 186 and hook up a fax machine.
I bought an ATA from CISCO and got the H323 image loaded but now i am stuck. I have no clue how to configure the zillion parameters so the altigen system recognizes the device. Altigen support have not been much help.
Has anyone done this ? any help appreciated.
Rodman
I am in the same boat. I don't have the Altigen VoIP card installed yet, but I am gearing up for it. The technician is installing the card tomorrow. I have 2 Cisco ATA 186 boxes ready to configure.
So far I have configured the two boxes with the latest h.323 image (3.1.2) and assigned static IP addresses (for testing). I then went into the config page (http://ww.xx.yy.zz/dev) and set the UID0 field as 4000 on one box, and 4001 on the other. I am able to call the other phone directly using the following syntax: 4001**w*x*y*z# where wxyz represents the ip address.
The next step is to configure the boxes to register with the altigen server as the gatekeeper and gateway.
Hope this helps. Share your experiences too! I am still working on this.
-Brad
------------------------------------- rodman wrote:
##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive
read and post WWW interface to your favorite newsgroup - comp.dcom.voice-over-ip - 3998 messages and counting! ##-----------------------------------------------##
ip address.
this.
-Brad
rodman Wrote:
I have successfully set up the Altigen VoIP card, and I have 2 altigen
IP phones that can make and receive calls. I have successfully
registered the Cisco ATA 186 with the Altigen system as the gatekeeper.
The Cisco ATA box can make calls to just about anywhere, but it cannot
receive calls from anywhere. I have .cap files from ethereal and log
files from debug mode (cisco's prserv.exe debug tool). If anyone is
interested in this issue, let me know at snipped-for-privacy@realbranding.com
Brad Smith Systems Adm> I am in the same boat. I don't have the Altigen VoIP card installed
