Cisco 804 ISDN and POTS phone busy - newbie
Oct 09, 2006 1 Replies
Greetings, I am trying to get the pots phone connected in port 1 to be able to call out when I pick it up. Right now it can only do that if the ISDN line is not being used. I think I have it set up to bump a data channel. Right now with one data channel being used I get a busy signal. I think it should open up the other channel when I pick up the phone and give me a dial tone. I get blank air for about 3 seconds and then a busy signal. I searched the newsgroups from Google and tried all of the suggestions. I am willing to erase everything and start the config all over if I have to. I've done this 3 times so far. I have also searched the Cisco website to see if there is anything I can try. Some of the information is for IOS 12.3 and higher and the options are not available to me, such as directing an incoming call to any port not in use. Here is a copy of my show run listing. I hope I didn't leave in too much informaion like one person who left their username, password, and ISP phone number. It was suggested that he change them as soon as possible. If I took out too much please say.
+++++++++++ show run Building configuration...
Current configuration: ! version 12.1 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname magic ! boot buffersize 8075 boot system flash magic enable secret 5 ! username password 7 ! ! ! ! ! dial-peer voice 1 pots call-waiting ring 0 port 1 destination-pattern 275**** ! dial-peer voice 2 pots call-waiting ring 0 port 1 destination-pattern 275oooo ! pots country US pots tone-source remote pots line-type type1 ! ip subnet-zero no ip source-route ! isdn switch-type basic-ni ! ! ! interface Ethernet0 ip address 10.0.0.1 255.255.255.0 ip access-group 121 in no ip proxy-arp ip nat inside ! interface BRI0 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type basic-ni isdn spid1 xxx275****0101 275**** isdn spid2 xxx275oooo0101 275oooo isdn voice-priority 275**** in always isdn voice-priority 275**** out always isdn voice-priority 275oooo in conditional isdn voice-priority 275oooo out conditional isdn incoming-voice modem no cdp enable ppp authentication chap pap callin ppp multilink ! interface Dialer1 description ISP ip address negotiated ip access-group 121 in no ip proxy-arp ip nat outside encapsulation ppp no ip split-horizon dialer remote-name remote dialer pool 1 dialer idle-timeout 300 dialer string 276uuuu class DialClass dialer string 276vvvv class DialClass dialer hold-queue 10 dialer load-threshold 10 either dialer-group 1 pulse-time 0 ppp authentication chap pap callin ppp chap hostname username ppp chap password 7 ppp pap sent-username gbushta password 7 ppp multilink ! ip nat inside source list 18 interface Dialer1 overload no ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! map-class dialer DialClass access-list 18 permit 10.0.0.0 0.0.0.255 access-list 121 deny udp any eq netbios-dgm any access-list 121 deny udp any eq netbios-ns any access-list 121 deny udp any eq netbios-ss any access-list 121 deny tcp any eq 137 any access-list 121 deny tcp any eq 138 any access-list 121 deny tcp any eq 139 any access-list 121 permit ip any any time-range TIME dialer-list 1 protocol ip permit ! line con 0 exec-timeout 120 0 transport input none stopbits 1 line vty 0 4 exec-timeout 0 0 login local ! ! time-range TIME periodic daily 0:00 to 23:59 ! end
magic#
+++++++++++++++++++ Thanks, Greg
Apparantly the IOS version I have (12.1) doesn't properly support the isdn voice-priority option. Now to figure out how to get an update. :-/
