MGCP doesn't work with CallManager 4.1(2)<-->1760. But why?
Mar 17, 2005 0 Replies
Hi
I'm experiencing troubles with Cisco CallManager 4.1(2) and 1760 router (IOS Version 12.3(11)T3) as a MGCP-gateway. I'm trying to get CM and 1760 to work with MGCP and have succeeded to establish some sort of connection between them (as shown in **debug mgcp packets**). Gateway Configuration in CM also shows "Registered with Cisco CallManager". 1760-gateway has been configured basically from the CM with some commands to router side also (**show running-config**).
My problem is that I have not managed to receive any MGCP packets other than these while trying to call through gateway (debug mgcp packets on) and the call won't go through (I'm using ISDN BRI port and line to connect 1760 to PBX and it should be OK.). I have also created a Route Pattern to CallManager and it should also be correct. Does anyone have any ideas about this? Why won't I see any other MGCP-packets? Why won't call get routed?
sh run, sh isdn status, sh int bri 0/1, debug mgcp packets and sh mgcp
-command outputs are attached.
**1760 show running-config** gwtodx200#sh running-config Building configuration...
Current configuration : 1644 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname gwtodx200 ! boot-start-marker boot-end-marker ! ! tdm clock bri-auto mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 voice-card 0 ! no aaa new-model ip subnet-zero ip cef ! ! ! no ftp-server write-enable isdn switch-type basic-net3 ! ! ccm-manager mgcp ccm-manager music-on-hold ccm-manager config server 192.168.9.2 ccm-manager config ! ! interface FastEthernet0/0 ip address 192.168.10.10 255.255.255.0 speed auto ! interface BRI0/0 no ip address shutdown isdn switch-type basic-net3 ! interface BRI0/1 no ip address isdn switch-type basic-net3 isdn tei-negotiation first-call isdn point-to-point-setup isdn incoming-voice voice isdn bind-l3 ccm-manager service mgcp isdn skipsend-idverify ! router eigrp 1234 network 192.168.9.0 network 192.168.10.0 auto-summary ! ip classless ! no ip http server ! ! control-plane ! ! ! voice-port 0/0 ! voice-port 0/1 compand-type a-law cptone FI ! mgcp mgcp call-agent 192.168.9.2 service-type mgcp version 0.1 mgcp dtmf-relay voip codec all mode out-of-band mgcp rtp unreachable timeout 1000 action notify mgcp package-capability rtp-package no mgcp package-capability res-package mgcp package-capability sst-package no mgcp package-capability fxr-package no mgcp timer receive-rtcp mgcp sdp simple mgcp fax t38 inhibit mgcp rtp payload-type g726r16 static ! mgcp profile default ! ! dial-peer voice 1 pots application mgcpapp port 0/1 ! ! line con 0 line aux 0 line vty 0 4 login ! end
**sh isdn status** Global ISDN Switchtype = basic-net3 ISDN BRI0/0 interface dsl 0, interface ISDN Switchtype = basic-net3 Layer 1 Status: SHUTDOWN Layer 2 Status: Layer 2 NOT Activated Layer 3 Status: 0 Active Layer 3 Call(s) Active dsl 0 CCBs = 0 The Free Channel Mask: 0x00000000
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not appl y
ISDN BRI0/1 interface dsl 1, interface ISDN Switchtype = basic-net3 L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER
0x0003 Layer 1 Status: ACTIVE Layer 2 Status: TEI = 65, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED Layer 3 Status: 0 Active Layer 3 Call(s) CCB:callid=800B, sapi=0, ces=1, B-chan=1, calltype=DATA, hdlctype=HDLC-T RUNK Active dsl 1 CCBs = 1 The Free Channel Mask: 0x80000002 Total Allocated ISDN CCBs = 1
**sh isdn status**
**sh int bri 0/1** gwtodx200#sh int bri 0/1 BRI0/1 is up, line protocol is up (spoofing) Hardware is Voice NT or TE BRI MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation VOICE, loopback not set Last input 00:00:05, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/2/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 48 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 19903 packets input, 84480 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 2 input errors, 2 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort 16992 packets output, 68549 bytes, 0 underruns 0 output errors, 0 collisions, 9 interface resets 0 output buffer failures, 0 output buffers swapped out 35 carrier transitions
**sh int bri 0/1**'
*Mar 7 20:28:40.303: MGCP Packet sent to 192.168.9.2:2427--->
NTFY 12114 *@gwtodx200 MGCP 0.1 X: 0 O:
200 12114
200 12114
