Grandstream phone dead - help me please
Jan 08, 2005 13 Replies
Most relevant reply
Christen Fihl
Very simple logic used If TFTP server found, and a better version found on server, then download and install. No delays, no trigger, nothing else If you have your own TFTP server (like SolarWinds server ( you could just start the server program on your own computer, whenever…
Hello,
I'm using iconnecthere, I have a router netgear DG834G 54mbit and a DSL line.
I had 2 grandstream connected to the router plus a Zyxel wifi 2000,
I had registered the 2 grandstream and were working fine.
Today, some hours ago, I see that the display of the sip phones become blue and if I I touched the menu or numbers of the keyboard nothing can be changed, I cannot place a call etc etc..
so I think .. reboot all, I go to digit the IPs and nothing.. so I decide to reboot the router, when I did it, I see that the display of the 2 grandestram become blue without any text displayed.
I cannot do nothing, seem dead all, I can see something that is flashing in red under the keyboard, as if the phone is out of service or have some proplem I don't know why.
I cannot reach the IP of the phones, while the router yes and seem ok.
I'm europe and the sip provider is in new york.
Then, if can help, in the same moment stopeed to work my VPN that is done with Usa always.
Can be something due network problems with Usa from Europe?
Can I do something, just wait or the grandstream are gone bad? I had it since 2 days only!! are new .. I really don't know what to do,
help me thanks!!!
Grandstream are killed if they are downloading new software (maybe automatically if configured to do so) AND the connection is stopped duing the update.
I have a killed one myself :( No switches inside to reset to factory setting. I just had to waste some more money on a new device (another company this time!)
Sorry, not much help from my part then
"Christen Fihl" ha scritto nel messaggio news: snipped-for-privacy@individual.net...
is incredible what I read!
However just right now I have the VPN again up, the problem is that the grand stream don't react, I will try to connect to the ip and reboot... but if I read what you read.. I need to think to start to kry,
I update you soon
nothing... the display is blue... and dead ...
I HAVEN'T SEEN ANY DOWNLOAD ... and you say that we have not warranty, good to know, I hope soon to have a better phone to choose becouse this is a big delution.
The manual say something like (out of my head): "do not interrupt the firmware update as ...."
Maybe a warranty claim can be issued, I did not try to use it.
in may pack there was not the manual, and however I never seen the download, I just seen the phone highlight with a blue and stop, then was not possible to click or move something in the menu', buttons etc.. very strange
however, now I'm buying 2 new phones, where to keep updated the phone with the latest firmware and how to say to do not update automatically, and I repeat, I haven't seen this today, and he is dead in a strange way.
You can disable the update function by not having a "TFTP address" ie set it to 0.0.0.0 That is if you can get into the updatepage of the phone by browsing to its IP address and having the password for it.
You can then update a few times a year (put in the TFTP address), if you think you would gain anything doing this.
My dead phone reacts exactly as yours. Sounds as dead as mine.
ok, where can I find the manual of grandstream? and, if I put then the IP address, in ho may seconds decide the phone to make the upgrade? I still don't understand, becouse, I used the phone 2 days... and today happened all this.
bye and thanks
in the manual I have found in the website is not clear in how many seconds this update will start automatically.
That's all, have you got an idea how to do a safe upgrade? and where to read the upgrade benefits? the ring tones with the ring tone tools are interesting, how many ring tone have the grandstream becouse I had the time to use only the default ring...
thanks
Grandstream will always check its TFTP server to look for new updates. Only way to disable is to remove TFTP address. Safe update is best to do on a local network with own TFTP server, to make interruptions minimal, or else :(
My VoIP supplier had there own TFTP server, and toll users which version had which features. You still had to accept latest version or disable the feature. Grandstream has a firmware page on
Manual:
see page
25 on TFTP updates for this:
Sorry for butting in but you seem to be missing the question, how often does the phone look for the server?
) you could just start the server program on your own computer, whenever you want to upgrade.
If it's the same as my Grandstream ATA-486 adaptor, it checks the TFTP server *only* on power-up. So you would need to cycle the power, if it finds a new edition of the firmware it will download and install it.
See above.
Ivor
If I delete the ip server for the TFTP of Iconnecthere.com and then I download the firmware in that page, can I simply upload it from the configuration web page? Is it possible or I should do it via tftp adding the IP server?
And still I don't understand: if I add the Ip server where tftp when the phone will decide to download the firmware becouse this is not clear to me, if there is any command for initiate it, it when decide to do? after 24 hours? or what?
thank you
