USB SIP Phone- Help
Oct 11, 2004 6 Replies
Jump to replies (6)
I'm looking for a USB phone with SIP, that does NOT need any software for a computer to download, .ie...I can walk up to any broadband computer plug in the phone and get dial tone.
I see that there are Wi-fi phones out that allows you to connect like this today, but they seem to skip over the USB version.
Does anyone know of any phones ?
xcvzxcvzxcv cdfgsdaf sdafsadfas sdafasd
Cat walking on the keyboard?
Well they would have to get someone to merge some USB tcp technology into a sip phone... You don't see much usb network innovation. I rember the transfer files from one computer to anouther with the usb cable and this pricy unit .. but it was not worth the monies compared to a craossover cable.
Maybe there are some chip manufactors out there innovating some R&D into this market.. but untell they got something mass produced on the market its not gong to be a cheep usb ip phone.
I got my monies being saved when the Cell phone companies add a few Sip lines with WiFi and that becomes main stream. that my friend is gunna be dam cool. Maybe give the cellphone a etherconnection also.. make it a muilti data communicating device..
The future has so many possibilities..
Andeas wrote:
m:
You can do that now with a wifi equipped PDA running pocket Windows & software, Skype too. Fine if you already have PDA, too expensive if you just want wifi phone :-( Regards, Martin
