Hi, thanks for answering my question:
I want to install a PBX system (landline) in my home. I've heard, from sellers/installers, that you must have an individual wire from each jack going to where the phone line comes in (i.e. a different wire from each jack to one central location -- where the PBX would plug in). Before I order a system, I want to make sure that I have the proper wiring. I do not want to re-wire my home.
1) How do I check if I have this wiring in my home?
2) Most sellers say that if I do have this wiring, the Merlin Legend or Magix system is the only way to go. Are there any other Avaya/ Lucent/even Nortel systems that would work?
3) Is the Merlin Legend/Magix the best bet for a home PBX?
Thank you for your time, I look forward to your response!
Alex
[TELECOM Digest Editor's Note: My opinion is just that: IMO. I have a small PBX here in my home and I had to do this: The phone box was mounted on the outside, on a wall. The former arrangement was at that outside box I had ONE incoming phone _pair_ and THREE _pairs_ going out to around my house. The PBX could not be mounted outside of course; I wound up putting it inside on a wall in my computer room area. I had to bring ONE _pair_ of wires in for the phone line inbound, and THREE pairs had to run back outside to go from the PBX to the various stations known as 103, 104, and 105. (had to install those three pairs). On this six extension PBX, three of the extensions (100,
101, and 102) did not have to run back outside to get to their destinations. So, I had to in total have four _pairs_ of wires running to the phone demark box (and the pole) from the PBX. These went through a newly made hole in my wall, then tacked along the outside wall to the phone box (or demark) where one of the pairs connected to the (old) incoming pair; the other three pairs were hooked to the (old) three extensions around the house, via their original wiring).
For the second incoming line which had previously been by the computer only (a VOIP line), I used a 25-foot phone cord to run from the back of my router/ATA box on the computer over to the closet where the PBX unit is now mounted. Incoming calls (either the landline or the VOIP) default to station 100 which is aliased to also ring on '0'. I can answer or transfer any incoming call (either Vonage VOIP or landline) to any station desired by dialing *7 plus 100 or 0 to answer the call, press the flash key to get new dial tone then dial the three digit station number desired, or 0 if I wish to transfer to the 'operator'.
So I wound up using 4 new _pairs_ (out of a new six _pair_ cable) to get myself in and out of the outside demark to/from the PBX, and 3 existing _pairs_ to get to my bedroom, dining area and living room. Then I used three additional _pairs_ to get three extensions in the computer room area (which were already around) plus another _pair_ for the VOIP line.
Regards which PBX system works best, my situation may be unique, but I am using something called 'TotalCom', from Mike Sandman
