voicemail question for avaya partner
May 25, 2006 0 Replies
Hello I need a little assistance with programming a voicemail card for a avaya partner system. I have everything working except I want to turn the ring off for the extension that the mailbox is assigned to. If I turn the ring off then the mailbox will not answer the incoming call. I know I could use the DND feature but then the extension would not ring on the other lines. Here is what I want. I want line 2 to go directly to mailbox 2 assigned to extension 13. I do not want line 2 to ring on any extension just go straight to extension 13's mailbox. Any help on this is greatly appreciated! Thanks again.
