KX-T7433 message light
Jan 31, 2005 1 Replies
Most relevant reply
Carl Navarro
Guessing that it's on a TD-816/1232 from the intercom dial 700 and the extention. Dial 790 and if the phone doesn't beep, dial #. This should totally reset the phone. You might want to check the Panasonic web site for a dealer near you. Carl Navarro
We have one phone out of 13 that has the message light indicating a voice mail but when you check on the voice mail the message tells you there isn't any. How can we fix this?
Also, that same phone will not allow you to use the intercom system anymore. The company we used to install the phones is no longer in business and the manual we have for operating the system doesn't touch on either of these problems.
Carl Navarro
