Re: Question on Caller ID on Panasonic KX-TA624
Apr 07, 2005 0 Replies
Hello,
> We have a Panasonic KX-TA624 hybrid phone system along with the
> KXT-7735 phones. We have 4 phone lines and the caller ID card is
> properly set up on the system. When an incoming call comes in, each
> phone displays the CID information. However, if one person is on a call
> and another call comes in, they do not see caller ID information. The
> phone line display only lights. Is there a way to have the system
> display CID information on the other calls? I believe the other phone
> extensions that are not in use will see the CID information.
Did you read the manual? Under Call Waiting, you'll find that you have to turn the feature on. 7311# for outside call waiting.
Carl Navarro
