Fuse Panel Recommendation [telecom]
Sep 09, 2011 1 Replies
Can someone recommend a -48V DC fuse panel for a telecom rack that would meet two requirements:
- let us manually configure the fuse or circuit breaker for each piece of equipment, up to 30A per box (most equipment would be at or under 20A)
- show a spot reading of the total amps in current use across all devices that go through the fuse panel that are currently powered on
Trimm makes some really nice DC fuse and breaker panels. But, if you really want a built-in current meter, they only offer that on their 767 series panels, which are high current panels made to Verizon specs. They are nice panels, but be prepared for sticker shock...
Jim Bennett
************************************************** Speaking from a secure undisclosed location.
