Seeking DIY System for My Tenants Apartment
Jan 31, 2006 3 Replies
Jump to replies (3)
Would anyone like to recommend a system for an upstairs apartment that I'm renovating?
I would like:
- DIY wired system. Walls and ceilings are presently stripped bare.
- Easy to operate. Tenants will be using it, not me. This is a biggie.
- CSM capable. Whether they use it or not will be up to them.
- Override/operate ability for me.
- Anything else I forgot/might be nice....?
Apartment Specs:
- Floor: 2 nd
- Rooms: 4 + Hallway, railroad layout, bathroom off hallway.
- Doors: 2: 1 in front room, 1 in hallway. Both open to common hallway (shared with other upstairs apartment.)
- Windows: 2 facing street, 2 facing backyard, 4 facing central airshaft.
Thanks, Tom
I would recommend the Ademco Vista 20P.
Jim Rojas
================ OK, Ademco Vista 20P it is. Thanks Jim.
If you buy a kit make sure it includes a programming keypad like the 6160, with the basic keypads you cannot program the zones - well some people can but it's not recommend.
