Need help on reprogram a Faraday MPC 2000
Mar 29, 2007 2 Replies
I have a MPC 2000 to reprogram and know nothing about it
The I suggest you don't reprogram it
Programming or reprogramming an analog/addressable fire alarm is not something you do unless you have some training and experience. Stick to something safer, like brain surgery.
Even if someone here knew how to help you (and they do) I doubt they would. The liability is too great for one. For the record, since you say you don't know about the panel, do you know the difference between conventional, addressable and analog addressable panels?
