DSC Power 832 - PC5501Z Keypad - Zone 1 Question
Jun 06, 2006 4 Replies
Jump to replies (4)
Check your programming to see if you have zone one assigned to the keypad.
I've read the manual and have a question. Is the wiring for zone 1 different than the other zones? All of my other zones work fine except for zone 1. I know the contact is good and I have even replaced it on the panel with a jumper between ZN1 and COM and yet the system still sees zone 1 as open. Any suggestions?
-Russ
A jumper or a Resistor? Zone 1 works the same as the other zones. Try putting the resistor across zone one but make sure to disconnect the actual zone wires from it. This should narrow it down.
James
Zone programmed for NO EOLR maybe?
Figured it out. Actually it was because the keypad was setup to be used as a zone as well. I'm learning a great deal in this process and the people and messages in this group are helping. Thanks everyone!
