Downloading Tech Help Beta...
Jan 08, 2008 3 Replies
Jump to replies (3)
Anybody know off hand if it still contains a list of CID codes? Also, what is the 9 digit reporting format order? I keep forgetting.
that looks like the complete list.
I was wondering about the "9 digit format." When setting up a special format for Telguard Full Digitil units they request you to manually assign a
9 digit format reporting code for the test and test fail codes.
Isn't it just the 3-digit event code? At least it was when I was fooling around with them
1234 18 3131 01 015 6
where:
1234 = The account number (1234)
18 = The message type used to identify the message as Contact ID
3131 = The Event Qualifier (3) for a restoral, followed by the Event Code for Perimeter Burglary (131)
01 = The partition number (1)
015 = The zone number (015)
6 = The checksum (See Example 1)
