DMP XR200 panel requires Access Code *AFTER* power outage with dead lithium battery
May 25, 2026 Last reply: 5 months ago 1 Replies
I have an (admittedly) 20-year old DMP XR200 Alarm panel (FW 112). I have always been able to program it via either my keypad (using PROG) or via Remote Link software. I have never had to enter an access code when programming since I believe the lockout code was never set (and Remote Link shows it set to '0').
The other day I had a power outage and it seems like my Lithium button battery (BR2325 for the SRAM backup) was dead.
After replacing the Lithium battery and setting/unsetting the J16 panel reset jumper, and entering P-R-O-G, I got a request for an Access Code which never happened before.
I tried '0', '00000', '9', '99', '12345', '11111' etc. but nothing worked and I got "Access Denied".
I seem to be locked out of the panel -- even though I would have thought that the lockout code would restore unset (since it never required one before).
- I did notice there was a sticker on the panel saying: "CAUTION: Removing Lithium battery when power is not applied to panel will cause loss of programming and require panel to be returned to factory (LB0074)"
- I also noticed that the zone names and some of the keyboard messages seem to be filled with random characters
Is it possible that I am truly permanently locked out of the panel, requiring me to send the board back to DMP? (which probably will cost more than buying a used one)
Alternatively, is there some other underlying default lock code that gets set when all power (including the Lithium battery) is removed from the board?
Any ideas on how to fix this?
At this point I would rather not upgrade the panel, so if I can't fix it, my only choice might be to buy another used board 😞
try 6653
and the program manual is at
maybe that'll help...
RTS
