Recommended Temperature & Water sensors for use with DMP-XR200 panel?
Oct 27, 2005 3 Replies
Crash Gordon
ANY will work fine. You'll have to customize a zone response. I can help you with this later. |I would like to add a Temperature sensor and a Water sensor to my | DMP-XR200 based system. | | I was wondering what sensors work best with this panel? | | I am planning on placing…
I would like to add a Temperature sensor and a Water sensor to my DMP-XR200 based system.
I am planning on placing the water sensor in the basement.
I am thinking of placing the temperature sensor in the first floor bathroom (which tends to be the coldest room in the house since it has an outside wall but no direct heat vent) to serve as my "early warning system" if the heating fails.
Thanks, Jeff
I've only used the Sentrol 5501 (not sure if that's the correct model number...it's been a few years since I've used one)
Are you in the alarm business or DIYer?
| | Thanks -- but are there any brands, models, or features that I should | be looking for or are they all really the same.
Thanks -- but are there any brands, models, or features that I should be looking for or are they all really the same.
