opening/closing miniblinds
Apr 08, 2006 5 Replies
Jump to replies (5)
I'm looking for a way to open/close my miniblinds..i'm not so concerned about pulling them up/down, but just something to actuate the rod part that rotates the blinds into open/closed positions...
smarthome seems to offer a variety of vertical blind and drapery solutions, but nothing for horizontal miniblinds... I know some manufacturers offer all in one solutions where the blinds and the motor are all one piece, but i'm looking for an add-on solution to activate my existing miniblinds.
is anyone aware of a commercial product to handle this? i built a custom solution using lego mindstorms, but i'm looking for something with a bit more durability.
Here's a DIY article:
'miniblind%20motor'WorthingtonDistribution has this ready made motorized solution fromAuto Tilt for you for $44:
actually found it on the Smarthome site but it shows as discontinued.Enlarging the picture there revealed the AutoTilt brand name and asearch for that found it at Worthington. Enjoy!>
I'm looking for a way to open/close my miniblinds..i'm not so> concerned about pulling them up/down, but just something to actuate> the rod part that rotates the blinds into open/closed positions...>> smarthome seems to offer a variety of vertical blind and drapery> solutions, but nothing for horizontal miniblinds... I know some> manufacturers offer all in one solutions where the blinds and the>
motor are all one piece, but i'm looking for an add-on solution to> activate my existing miniblinds.>> is anyone aware of a commercial product to handle this? i built a> custom solution using lego mindstorms, but i'm looking for something>
motor are all one piece, but i'm looking for an add-on solution to> activate my existing miniblinds.>> is anyone aware of a commercial product to handle this? i buil t a> custom solution using lego mindstorms, but i'm looking for something> with a bit more durability.
What are you using for a Newsreader, Bruce?? There's no spacing in your reply.
'miniblind%20motor'Worthington Distribution has this ready made motorized solution fromAuto Tilt for you for $44:
You could interface the wireless remote to a computer controlled relay fairly easily. In fact, I do that to operate my front gate and and outside awning. Because wiring to these locations was a PITA I just ran leads from the remote control to a relay. When my automation program calls for the awning to go up or down the appropriate relay is momentaritly operated to, in essence, press the button on the remote.
'miniblind%20motor'> Worthington Distribution has this ready made motorized solution
'miniblind%20motor'>> Worthington Distribution has this ready made motorized solution
