Linksys BEFVP41 -- a first look
Apr 06, 2005 6 Replies
Jump to replies (6)
I purchased for testing
- a Linksys BEFVP41 "Ethernet Cable/DSL VPN Router" and
- a Linksys BEFSX41 "Broadband Firewall Router with 4-port Switch/VPN Endpoint"
I was hoping that the VPN capabilities of the FVP were sufficient to allow me to connect to our several PIXes from my SOHO, and hoping that the FSX VPN would be "good enough" to be able to recommend to potential telecommuting employees who do not need as many tunnels as I do.
I have now had a small amount of time to play with the FVP, but I have not had a chance to open the FSX as yet.
I had some initial problems with getting a wired connection to the FVP, with rather inconsistant results. Either there was a conflict with my wireless network connection having been activated first, or (more likely) the cable was too short and I was having some kind of physical wiring problems. Replacing the cable with a spare one I had around appeared to solve the problem; the ability of one of the
4 LAN ports to be crossed-over helped. The LAN ports are -not- auto- MDI-X though.
Once I had a connection, the majority of the configuration screens on the FVP are immediately recognizable to users of a number of other Linksys products such as the BEFW11S4.
There is no obvious way to SYSLOG anything; it appears that the logging function is the Linksys non-standard one. I have read that there is linux source available for the logger; I will have to check that out.
One can, though, set SNMP community strings. I have not yet attempted to browse the tree.
It appears that I have a "version 1" FVP; there is a "version 2" as well, whose firmware has been touched more recently. [Now I'm going to have to investigate to find out whether I should have been more specific about what I was buying...]
There is a VPN configuration tab, with a choice of DES/3DES, HMAC/SHA, IKE auto or manual, PFS available, and key lifetime specifiable. On the Advanced tab, one has a bit of control over the proposal orders, and can configure groups of 768 or 1024 bits (i.e., group 1 or group 2, but given by size not number.) There are no Certificate Authority options on the FVP, just a shared key, which is limited to 24 bytes (which can be entered in ASCII or hex.)
This revision of the FVP does NOT offer AES, VPN over SSL, or groups 5 or 7, and also does not offer any way to turn on AH.
Each "tunnel" may be configured for source and destination and remote security gateway. The source may be specified as an IP, a subnet, or an IP range. The destination may be specified as an IP, subnet, IP range, 'any', or 'host'. When 'host' is chosen, the implied host is the remote security gateway. [Plausibly this connects in the other IPSec mode.] Selecting 'Any' produces a message that is not immediately clear: leads me to wonder about the ability to use the FVP as an IPSec server (i.e., destination endpoint)... something I had been thinking of at the time of the purchase, but which had slipped my mind since. The box outside documentation implies it is possible; I have not read the manual yet ;-)
Notice in the description of tunnels that each tunnel corresponds what PIX would call a "security association", instead of corresponding to an IKE peer (as per the peer limits on the PIX 501.) That will not be a problem for me for the FVP, but it will certainly influence my use of the FSX if the configuration mechanism is the same. When I popped for the extra FSX I was certainly thinking in terms of IKE peers, not in terms of SA's.
We have 4 different subnets that our employees could plausibly want to access, and as well we have a dozen or so systems at HQ that we would want to be able to relay traffic for. I will need to experiment with split ACLs, and with the 'any' destination, and I might end up needing to essentially go for a VPN concentrator solution, handling all user traffic and sending it onward through tunnels or not as appropriate. I'm not keen on relaying all user traffic, though -- I'm not interested in having their private non-work traffic ending up going through our equipment, so if I can't get split ACLs to work, users that want to telecommute will likely be told that the FSX is not an option. I might still be able to deploy the FSX within a small remote office, though.
A note on the internal differences between the FVP and FSX: the FVP has a hardware VPN coprocessor, whereas the FSX does not. Sites such as tomsnetworking.com have some speed comparisons: the FVP is a fast device considering the low price (slightly over $US100), with the FSX being slower but still "fast enough" for typical DSL/cable subscribers.
Ah, I nearly forgot to say how my VPN experiments came out: looking up our current crypto dynamic map shared secret took longer than configuring a simple tunnel. My first iteration, 3DES HMAC was rejected by our PIX (if I recall correctly, it said it was not supported), but after a simple modification to 3DES SHA, the connection went completely smoothly, and the VPN tunnel was up in seconds.
Considering the firmware age, there is likely no NAT-T support in the firmware for the FVP revision 1 [but there plausibly is on the newer FSX firmware]: I will need to check.
So... if you are looking for a VPN hardware endpoint with SPI, for SOHO use, and 24-byte preshared key 3DES Group 2 is acceptable, then indications so far are that the Linksys BEFVP41 has no difficulty talking to a PIX.
I hope you don't depend on the Linksys to run a business.
I have pulled all of them out and either used a Netgear FVS318 or a real Cisco. You get what you pay for........
They are ok for a home user with minimal use, but not any serious use. IPSEC---3DES....you better buy a lot of spares.....
Tech Support is also horrible.....
Two months and you will through them out. I did.
Digital Doug
In article , Digital Doug top-posted: :I hope you don't depend on the Linksys to run a business.
:They are ok for a home user with minimal use, but not any serious use.
Would you have a few minutes to describe some of the issues you encountered?
:I have pulled all of them out and either used a Netgear FVS318 or a real :Cisco. :You get what you pay for........
Before selecting the Linksys BEFVP41, I looked first at a number of commodity products that were wireless + SPI + (for the better ones) VPN. The -best- that I could find had a user satisfaction rating of 5.9 out of 10 -- people were even more unhappy with the others (doesn't stop the companies from selling tons of the things though...) D-Link, Netgear, Linksys... user review after user review said, in essence, "This is a junk product that I wouldn't recommend to an enemy."
When I looked at the user reviews of the BEFVP41, there were some people who had had difficulties, but the postings were mostly review after review saying "This product has worked quite well, and I've been very happy with it." The FVS318 did not have as strong a user endorsement.
:Tech Support is also horrible.....
I have heard that about Linksys. I have heard much the same thing, only a bit more strongly, about Netgear. And the anecdotes about D-Link support are less flattering yet. :(
snipped-for-privacy@ibd.nrc-cnrc.gc.ca (Walter Roberson) wrote
Linksys doesn't have tech support as such. Here in the UK, the calls are routed to the Phillipines and there, after a long wait, they are answered by useless staff reading prepared scripts. I've had a few hours of this.
Very occassionally, the call gets connected to the UK office where somebody listens - but still nothing gets resolved.
Support emails are never responded to.
IME the stuff generally works well (never attempt using it without installing the latest firmware off their website!) but if it doesn't there is only one thing to do and that's to chuck it away and get something else.
The above comments could be equally applied to most consumer IT products today, unfortunately. It's also true for HP - astonishingly for a one-time world leader.
D-Link is bad, but not as bad as Belkin...
Peter.
-- Return address is invalid to help stop junk mail. E-mail replies to snipped-for-privacy@peter2000XY.co.uk but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary.
In article , Peter wrote: ;Linksys doesn't have tech support as such. Here in the UK, the calls ;are routed to the Phillipines and there, after a long wait, they are ;answered by useless staff reading prepared scripts. I've had a few ;hours of this.
Netgear outsources their front line tech support -- to India, I think it might be. The front line pretty quickly passed me up the chain to the second line support in the USA... which listened to my description and said that it sounded like I got a defective device and that I should return it. But Netgear company policy is No Return For Refunds, only exchange, and it was obvious to me that the problem was firmware problems that would not be repairable by simply exchanging the item.
The reseller wouldn't take the product back without an RMA number from the wholesaler, the wholesaler wouldn't issue an RMA without an RMA from Netgear, and Netgear wouldn't issue an RMA except for exchange. Catch-22.
Netgear gets points for -having- a second-line product support, and gets points for the front line answering the phone fairly quickly, and gets points for the front line passing me along fairly quickly. But I couldn't say that in that particular incident that the support was "useful".
[with regards to the Linksys products]
:IME the stuff generally works well (never attempt using it without :installing the latest firmware off their website!) but if it doesn't :there is only one thing to do and that's to chuck it away and get :something else.
I hear ya. I ran into a bug on the FVP the other day -- after the DHCP lease expired on the PC, the FVP would not renew the lease until I rebooted the FVP. I could imagine that in some situations that could be a serious problem; my potential uses happen to be such that fixed IP addresses are better anyhow, so I might be able to use the FVP successfully.
Funny you mention fixed IPs. I tried to config a Linksys wifi router (can't recall the type but it was the common one from ~ 1 year ago) for a fixed IP.
As soon as I disabled DHCP the thing basically stopped working, in all sorts of bizzare ways.
I don't think they ever tested it with DHCP disabled!
So now I just use it as a wifi access point. At the price, that's OK. There is works just fine with Linksys wifi adaptors like the WPC54G using WPA/PSK :) Not with a lot else though.
I can see why corporates go for Cisco gear. I used to run a couple of
803 ISDN routers. After getting the config right (which is a huge job creation scheme!!) they just run for years. The extra cost is trivial if one's time is worth anything at all.
I'd rather buy a Cisco product from Ebay than buy a new one from one of the "consumer" players. Recently I gave away my 803 routers; in
1999 they cost about US$1600 plus $500 for a flash upgrade and they now fetch about $30 on Ebay.
Peter.
:I can see why corporates go for Cisco gear. I used to run a couple of :803 ISDN routers. After getting the config right (which is a huge job :creation scheme!!) they just run for years. The extra cost is trivial :if one's time is worth anything at all.
Oddly, some sales reps came in to talk to me the other day, and were talking about Fortinet firewalls. They were from a bit of an amorphous consulting-type organization that also does sales (i.e., a VAR -- they'll sell you the equipment and sell you service in setting it up or helping configure it or helping out in emergencies.) They said that they pretty much used Cisco and Fortinet exclusively.
When they were talking to me about the Fortinet product, they were talking about it's reliability, which they compared to being similar to that of Cisco's. The way they put it was that Fortinet was similar to Cisco, in they knew that once they had made a sale and configured the product, that they could drive away saying to themselves, "Well, that's one place we'll never have to back to again" -- because [in their experience] once the Cisco [or Fortinet] was set up, it would just keep working away for years without needing attention.
I didn't have the heart to discuss hardware failures, design for redundancy, regular preventative maintenance testing of emergency procedures, or the need to upgrade IOS because of security problems discovered. [I do not mean to imply that Cisco "has a problem" in any of these areas: these issues are simply facts of life in non-trivial networks.]
