getting inside X-10 DS7000 controller
Mar 20, 2005 1 Replies
Can anyone tell me how to get the case apart on my DS7000? I want to add a switch to disable the siren. I can only find one screw in the battery compartment.
I wonder too, if the DS7000 is compatible with the components in the Radio Shack Security System 49-1000.
Thanks for any help
Should be under the "self sticking" plastic pods.
I already this kind of mod by adding a potentiometer in place of a switch.
Used value was Logartihmic 4.7 K (if I remember well).
Hope it helps
Thierry
