ZoneAlarm Infected
Nov 16, 2005 7 Replies
Jump to replies (7)
Most likely it is just NAV being ridiculous.. What happens when you run a full scan on your HD?
Well, I am certainly no expert in malware, but I'd not worry much about it unless you see repeat messages or other signs of something wrong.
Hi, I have ZoneAlarm Pro 6.0667 and NAV 2006. I have a netgear router and with my DSL modem off I turned on ZA to prep for going online. I recieved the following alert from NAV 2006: Rule "Default Block Shiva Burka Trojan horse" blocked communication. Local address: All local network adapters(1600). Process name is "C:\\WINDOWS\\SYSTEM32\\ZoneLabs\\vsmon.exe".
Any comments would be welcome. Is my True Vector infected? I did have one incidence where the ZA icon turned red with a yellow X on it a few days back.
Brian
Kerodo I ran a full scan with NAV 2006 and it found no problem. Since the alleged malware was a trojan I also ran scans with A Squared and Webroot's Spysweeper with clean results.
Brian
Am Tue, 15 Nov 2005 21:38:31 -0800 schrieb Kerodo:
Well, so you'd better don't write anything about malware.
Well, as you already said, you are no expert in malware ...
Wolfgang
Are we getting hard up for posting material Wolfgang? That post is a week old now.. :-)
Speed is not everything that makes a good comment.
Wolfgang
