Zone Alarm deleting cookies always
Apr 01, 2006 6 Replies
Jump to replies (6)
I have set up Zone Alarm cookie control to off and yet it is still deleting cookies. Does any one know how to solve this problem?
Thanks John
John, Are you using the Cache Cleaner? If you are, you have to hit the custom button to choose which cookies to keep. Hit the IE/MSN Tab, and the button to select is at the bottom of the page. Move cookies to keep into the other box . Otherwise, ZAP will delete them along with the other files. I'm using 4.5.594.
charlieR
I am not using Cache Cleaner. I do not know which version I am using since there is no place to read the version but I bought the software around November 2005. I don't see any IE/MSN tab
Thanks John
charlie R wrote:
Look in ZA under Overview/ProductInfo for version #.
Craig
Thanks Craig,
My version is 6.1.744.001
John
Craig wrote:
I found where the IE/MSN tab is. That was the course of the problem as the clean cache was checked.
Thanks Charlie
You're welcome. Thanks for posting back.
charlie R
