Spybot problem?
Jul 09, 2005 3 Replies
Patrick
Try adware, none of the spyware removal programs remove all of the junk flying around on the net.
After scanning I always get the same 27 entries to remove. I do remove them, rescan and they are still there. They are all tracking cookies.
Advertising.com 21 entries Avenue A, Inc Double Click Fast Click MediaPlex
How do I get rid of them forever. I'm set to autoimmunize and have even manually immunized.
Are these cookies? If so, either find a cookie blocker, add them to blocked cookies in your browser. If you are using IE (try Firefox instead!!) try IE-SPYAD, which fills your restricted zones with many nasty sites to limit what they can do:
Avoid the adverts that come from those sites, for example by using a hosts file. See
Andrew
