Sonicwall Pro 200 VPN Stops
Aug 04, 2006 0 Replies
I have a Sonicwall Pro 200 Firewall. The VPN works fine for a while, but after time you are unable to connect. You can reset the Firewall thru the GUI and it works again for a while until it stops allowing connections again.
Thanks
Kevin Jernigan
