Inactivity timeout for SonicWALL Pro 3060
Nov 06, 2006 0 Replies
Hi There,
I am running SonicWALL Enhanced version 3.0.0.10-41e on a SonicWALL Pro
3060. We are using Global VPN Client version 310_556. Under the Firewall rule settings for the VPN connection, the TCP inactivity timeout is set to 5 minutes. However, the connections never time out, and stay up until manually terminated by the user. SonicWALL support has not been able to help us with this. They suggested we drop back to the client version 210_111, but we have seen no difference in behavior. Any ideas? Thanks.
