Hi, I have Windows 2003, and i've tried 10 times installing, uninstalling and reinstalling SecuRemote, but it refuses to run - always with the same errors.
the errors are:
1) when the computer starts up, there is an alert that says "SecuRemote had an internal error" or something line that.
2) when i try to start the service manually, it tries for a few seconds, and then stops. After that, there is an error in the event viewer: "VPN-1 SecureClient Service failure in initialization - InitializeService"
3) when i look at the log, there are a bunch of errors there: dtvdevm_ipassignment_service_recovery : enter [dtrtm] dtvdevm_open_om_key : failed to open registry key : The system cannot find the file specified. [dtrtm] dtvdevm_add_domain_to_dns_suffixes : failed to open backup key [dtrtm] dtvdevm_open_om_key : failed to open registry key : The system cannot find the file specified.
[PolMgr] PolMgr::Failed to start events from fwcpii [PluginMan WatchPoint] General unknown error occured, abort [WatchPoint Fwcsssys PluginMan] FWCSSSYS: Plugin Manager failed start Initialize phase error 0xc0000001
I've tried the advice wit hthe userC.C file, but the write access was ok.
Does anyone have any idea???
