recommend
May 19, 2005 3 Replies
Jump to replies (3)
I reccomend not getting an all in one device. Get a seperate access point and GOOD firewall (hint - netgear, dlink and linksys do not make any good firewalls IMO)
I am looking for a 108Mbps wireless cable router, with built in firewall and NAT (preferably with a web configuration utility). There seem to be loads about what do people recommend?
Thanks.
None of those units are Firewalls, they are simple NAT devices.
Also, when you setup 108mbps, almost all of them require that you disable most of the security options.
what brand are the cards ? I use a 2100 D-Link which functions well ( its behind a Linux box though )
