Rec for a firewall that's light on resource-usage
Aug 25, 2005 4 Replies
Jump to replies (4)
Sometimes Sygate lags my system and internet connection.
Can anyone recommend a firewall that's a little "lighter"? Thanks.
Forgot to mention I have XP Home SP2 (I'd use the Windows firewall, but it doesn't have outbound protection.)
Just use the Windows-Firewall. Sygate has horribly security design flaws anyway, like the fact, that the system services of Sygate "Personal Firewall" are opening windows. And with Sygate a SelfDoS is possible.
Yours, VB.
"Outbound protection" of "Personal Firewalls" does not work at all. It can only control software, which allows to be controlled.
Yours, VB.
Use windows firewall with a good trojan stopper. I use BOclean 412. It even stops Leaktest
