RDP from outside network
Jul 13, 2006 3 Replies
Jump to replies (3)
RDP from outside network open original image
I apologize for cross posting this issue to multiple lists, but it is necessary because there are a few different technologies and solutions that require assistance from different professionals.
First of all, I am still fairly new to networking, so please be gentle. I need to allow RDP connections to a server from outside of the LAN. VPN is out because of multiple VPN clients on remote computer that are conflicting. In the Windows group, it was suggested that I "create a tunnel through the firewall" and change the default port that the RDP service listens for on the server. First of all, is this a good solution, and second of all, how do I configure this on the firewall??
Thanks in advance for all of your help and suggestions.
Sincerely,
Matt Atkins
No. You allow remote connections into your LAN. That's always a bad thing. Put the server into a DMZ, set up an SSH server (e.g. on the Windows-Server) and forward Port 22 to the host running the SSH server. Then you can establish an SSH tunnel and connect to your Terminal Server through this encrypted tunnel.
You need to forward a port (22/tcp if you want to tunnel RDP through SSH, which I'd recommend, or 3389/tcp for RDP without tunneling). How this is configured depends on what firewall you have in place.
cu
59cobalt
You could also just forward the port since RDP is encrypted -- however, keep in mind that it's only 128 bit and not all data is encrypyed.
-Gary
Now that Microsoft' Virtual PC software is free, I suggest you set up a virtual instance and use it for the VPN client. One of our consultants has a separate virtual machine for every client they work for. That keeps all of the configs and files and VPN clienst completely separate.
Ray
