RDP ?? ????????? ????????? ?????? ???????
Aug 13, 2007 1 Replies
Victor Frolov
Hello, If you need a help in russian - ask on the cisco forum on for example. WBR, Victor j> ??????? ???! j> j> ??????? ??? RDP ??????????? ????, ????? ?????????? ???????, Rdp ????? j> (?? ????? ????? Ipsec), ? ???????????? ? ????????? ??????? ?? j> ??????????. j> j> ? ???…
RDP ?? ????????? ????????? ?????? ??????? open original image
??????? ??? RDP ??????????? ????, ????? ?????????? ???????, Rdp ????? (?? ????? ????? Ipsec), ? ???????????? ? ????????? ??????? ?? ??????????.
==================== Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 auto interface ethernet2 auto shutdown nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 intf2 security4 enable password DMlb9btPxomkHr3X encrypted passwd DMlb9btPxomkHr3X encrypted hostname MC-PIX515 domain-name xxxx.ru fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list acl_in permit udp 172.16.101.0 255.255.255.0 any eq domain access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq www access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq https access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq aol access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq pop3 access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq ftp access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 3389 access-list acl_in permit icmp any any access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq ssh access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 4899 access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.16.35.0
255.255.255.0 access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.16.25.0
255.255.255.0 access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 441 access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq smtp access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.17.1.0
255.255.255.0 access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 10021 access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 10149
Hello,
for example.
WBR, Victor
j> ??????? ???! j> j> ??????? ??? RDP ??????????? ????, ????? ?????????? ???????, Rdp ????? j> (?? ????? ????? Ipsec), ? ???????????? ? ????????? ??????? ?? j> ??????????. j> j> ? ??? ????? ???? ???? ?? ??????????? j> j> ==================== j> Building configuration... j> : Saved j> : j> PIX Version 6.3(5) j> interface ethernet0 auto j> interface ethernet1 auto j> interface ethernet2 auto shutdown j> nameif ethernet0 outside security0 j> nameif ethernet1 inside security100 j> nameif ethernet2 intf2 security4 j> enable password DMlb9btPxomkHr3X encrypted j> passwd DMlb9btPxomkHr3X encrypted j> hostname MC-PIX515 j> domain-name xxxx.ru j> fixup protocol dns maximum-length 512 j> fixup protocol ftp 21 j> fixup protocol h323 h225 1720 j> fixup protocol h323 ras 1718-1719 j> fixup protocol http 80 j> fixup protocol rsh 514 j> fixup protocol rtsp 554 j> fixup protocol sip 5060 j> fixup protocol sip udp 5060 j> fixup protocol skinny 2000 j> no fixup protocol smtp 25 j> fixup protocol sqlnet 1521 j> fixup protocol tftp 69 j> names j> access-list acl_in permit udp 172.16.101.0 255.255.255.0 any eq j> domain j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq www j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq https j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq aol j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq pop3 j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq ftp j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 3389 j> access-list acl_in permit icmp any any j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq ssh j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 4899 j> access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.16.35.0 j> 255.255.255.0 j> access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.16.25.0 j> 255.255.255.0 j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 441 j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq smtp j> access-list acl_in permit ip 172.16.101.0 255.255.255.0 172.17.1.0 j> 255.255.255.0 j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 10021 j> access-list acl_in permit tcp 172.16.101.0 255.255.255.0 any eq 10149 WBR, FROLOV Victor
