Problem with SecureClient (EA) and Vista
Jan 20, 2007 2 Replies
I am using SecureClient for Vista (R60 HFA2 EA (Build 008)) on Vista RTM. It works perfect when using a network card (wired or wireless) to connect to our site, but when I use a modem connection (in my case an UMTS-Card), Everything looks good and I get a "connection succeeded", but no connection to our Intranet is possible. When I have a look at the status information, I see that the Office Mode says "IP assigned: failed". And when I do an ipconfig /all the Checkpoint virtal adapter says "not connected".
Does anyone have the same problem? Any solutions?
Thanks, Stephan
I'm having the exact problem has you subscribed. With my UMTS/HSDPA card and with my normal internet connection (wired, wireless) Have you got any idea how you get the wired/wireless part working?
Thanks, Michiel
I installed the new Version (Build 012) and the Problem ist not solved. Still the same. I am very disapointed.
Still waiting for an solution.
Best regards, Stephan
