Netscreen 204 to 5XT tunnel
May 02, 2006 2 Replies
Am at my wits end...
We've got a Netscreen 204 and trying to connect it to a 5xt.
The tunnel is working- from the console to console I can ping each other- no problem.
The issue exists when I try to ping clients on either side- they cannot seem to talk. The clients can ping their respective gateways.
Any help would be awesome.
snipped-for-privacy@gmail.com schrieb:
Do you see anything from these connection attempts in the packet-filter logs?
You have to allow traffic between the two networks through the tunnel so you might need to look at the ruleset first. The general approach is: Look at the logs of both gateways. If the tunnel comes up, it can only be a filtering and/or routing problem.
Wolfgang
Have fixed a similare problem, here the cause was the mtu size.
Hopefully this will help. Herman
