NAV 2005 and Netgear FR114P
Jul 20, 2005 2 Replies
Is the above good enough for home use?
Only using for one PC w/ cable modem and VOIP.
Thanks
I also use Spybot, and I was using MS Anti-Spyware, but it was a drag on my machine.
Thanks!
You're doing better than most.
Hey, use WW and watch the wall just in case malware compromises the machine and circumvents and defeats Norton.
Duane :)
