Tell me it aint so... it appears that a blank login and password is accepted from the internet for full administrator rights on the WRV54G. Is there any way to turn this off?
Thanks
Thanks
snipped-for-privacy@emiboston.com (klubar) wrote in news:e59a2340.0407201611.1e55ccd3 @posting.google.com:
It's called router configuration. The router has an Admin screen where a user-id and psw can be set by the administrator of the router. If you forget either one and cannot login to the router, then the *Reset* button held down for 30 seconds will reset it back to the factory defaults, including the user-id and psw which are apparently blanks.
I suggest that you RTM.
Duane :)
Perhaps my post wasn't clear enough... I can log in using the user name and password that was set in the admin screen OR I can log in leaving both the user name and password blank.
Linksys recommended exchanging this unit for a new one which I did. The new one did not have this problem, so I must have gotten a defective unit. (I'm a little surprised as I thought the login and built-in web server would be part of the firmware.)
FYI... the factory defaults on this unit are not blank and blank.
