Help Uninstalling Checkpoint
May 22, 2005 1 Replies
Help Uninstalling Checkpoint open original image
Hello all,
I wonder if someone could help me figure why I'm unable to uninstall Firewall-1.
The process I go through is as follows:
  1. I go to 'Add/Remove Programs'
  1. I highlight 'Check Point VPN-1 & Firewall-1' and Click on 'Change/Remove'
  2. The uninstall shield runs as though its about to uninstall and then gives me the message "Checkpoint is already installed - to remove it use 'Add/Remove Programs'. Which is silly because I'm already using 'Add/Remove Programs'
Has anybody else come across this problem? If so, can you please let me know how you fixed it?
Cheers
Carlton
