SonicWall TZ170
May 22, 2005 4 Replies
Jump to replies (4)
What is the easiest way to see the IP addresses of all of the users that are accessing the Internet through the SonicWall TZ170? I am not running DHCP; all users have a static IP. I would like to see not only the users but also their bandwidth usage. Thank you very much.
WallWatcher should do that if you are Win; I can't tell from your headers, they're google. Why not use a newsagent? -- much better.
It handles lotsa routers including that tz170
If the SonicWALL has the latest firmware (3.1.0.2) then you can go to System | Diagnostics and select Active Connections Monitor from the dropdown. Upon the screen refreshing you'll have a list of all internal IP's passing traffic through the SonicWALL. Click the Refresh button in the upper right to do exactly that...
Two options: - in the Sonicwall management go to LOG/REPORTS/ select Bandwidth Usage by IP Address, click start data collection - or buy Sonicwalls Viewpoint Reporting system, it gives you lots of nice info about bandwidth, attacks, protocol use, etc and its not too expensive
