H/W Firewall-Router Recommendation
Jan 25, 2007 1 Replies
Subject says it all. With the current multitide of choices, what is a particularly good hardware unit for a fixed wireless broadband inet connection where security is of the principal concern? May have the need for 1 or 2 additional computers tied in at a later date.
You didn't provide enough information.
What are you protecting?
A home or small office without a lot of money could go as cheap as a=20 DFL-700 Appliance and add wireless AP units are needed. I don't like=20 firewalls that include wireless in the appliance, your options are=20 limited.
If you get a firewall and then drop AP?s where needed you can upgrade=20 your wireless solution without having to change the expensive firewall=20 also.
If money is not an object, I would purchase a WatchGuard firewall and=20 then AP units.
--=20
snipped-for-privacy@rrohio.com remove 999 in order to email me
