Firewall settings - incomplete TCP/UDP sessions
Jan 24, 2007 1 Replies
Most relevant reply
Sebastian Gottschalk
Huh? Now that's technical nonsense. I really fail to see any such DoS condition due to allowing as many connections as you want and need, and neither do I have any technical reference that anyone ever mentioned such a scenario. And in fact you'd rather DoS yourself with a too…
Hello,
I've had increasing problems with my h/w firewall over the past weeks due to 'syn flood to host (outbound)' problems. Turns out my modded version of firefox triggers the f/w to hysterically shut down the connection (flood control). (I still don't know why this has only recently become a problem, as I've made NO h/w or s/w changes, and have no viruses/spyware.)
I've basically tried to desensitise the f/w by adjusting: 'Maximum incomplete TCP/UDP sessions number from same host', (which was originally 10) to 50 (max). This seems to work for the moment.
I don't want to set this too high, leaving my network vulnerable to dos attacks, but I also don't want my surfing restricted by my own firewall(!) What is the correct (permissible) maximum value I should have this set to?
And in fact you'd rather DoS yourself with a too low setting.
16777215 (2**24-1), the maximum.
