Connecting 2 networks
May 11, 2005 4 Replies
Jump to replies (4)
For testing purposes, I am trying to connect 2 PC's on different subnets via a Win 2003 server with Routing and Remote Access.
I have the following setup:
PC1 ip: 192.168.254.1 subnet: 255.255.255.0 dgway: 192.168.254.252
Win2003 Server nic1: ip: 192.168.254.250 subnet: 255.255.255.0 dgway:
nic2: ip: 192.168.253.254 subnet: 255.255.255.0 dgway:
PC2 ip: 192.168.253.10 subnet: 255.255.255.0 dgway: 192.168.253.254
On 192.168.254.252 is our Cisco PIX firewall through which we connect to the Internet.
I understand I need to add a static route to the firewall, so I have added:
route inside 192.168.253.0 255.255.255.0 192.168.254.250
I am unable to connect PC1 and PC2 together. I can from PC2 to
192.168.253.254 and 192.168.254.250.
It has been suggested to me that I need to allow ICMP redirect packets in the rules on the firewall. However I am unsure with the exact command to use.
Any help or other suggestions would be appreciated.
Martin
Does PC1 also have a route to 192.168.253.0/24 via 192.168.254.250?
Sunny
There is no route set on PC1. I was trying to achieve this without routing on either PC.
Martin
You have three choices:
- Recable the network such that PC2 is reachable via PC1's default gateway
- Configure the firewall to send an ICMP redirect when PC1 tries to reach PC2 via the firewall. I don't do PIX so can't help with the exact command.
- Add a route to PC1 telling it how to get to PC2
Sunny
Thanks - its the ICMP redirect option that I'm trying to find out about. When I try and set this up on the PIX on the inside interface I get an error about cannot set on the same security level.
Does anyone know how I should set this on the PIX?
TIA
Martin
